Old 03-05-2020, 09:02 PM   #1
FOMOCOAU
Default AU Clock spring.
I m replacing the clock spring on my AU1..due to the horn not working from the pad..and cruise control illuminating on the dash but not functioning. just wondering if there are any precautions that need to be followed fitting a clock spring?
FOMOCOAU is offline   Reply With Quote Multi-Quote with this Post
Old 03-05-2020, 09:50 PM   #2
FERG_51
Default Re: AU Clock spring.
Keep steering straight and don't turn clock spring until its fitted.
FERG_51 is offline   Reply With Quote Multi-Quote with this Post
Old 11-05-2020, 09:14 PM   #3
FOMOCOAU
I purchased a used clock spring for $55 from a wrecker.. once fitted the horn and cruise now function.
Old 15-08-2020, 03:57 PM   #4
Dingo
Ford T3 Partsologist
Dingo's Avatar
I need to do the same but the WM has no instruction on removing the steering wheel only ref to making sure to disarm air bag which ive done
Do i need to secure column to undo the steering wheel torx bolt, as its tight the wheel is moving as i try and undo the bolt any info would be helpful
Thanx in advance
2002 Blueprint T3 TE50 Manual Koni Suspension # 161
T-Series Club of Australia - www.tseriesclub.org
Dingo is offline   Reply With Quote Multi-Quote with this Post
Old 15-08-2020, 06:48 PM   #5
Dingo
Dingo's Avatar
All good got the bolt undone spent all arvo trying to budge wheel of by whacking and rocking etc will not budge so used a puller still wont budge hahahaha its just peeled the alloy away from the centre now im really in trouble if anyone can help can you give me a call on 0439 711 028 coz i have no idea how this going to come off now - its a T3 momo steering wheel
Thanx Darren
