Old 21-05-2019, 12:22 AM   #1
allenford
allenford's Avatar
Default Fuel miles on au2 sr
I want best mile's I could get
227 ks just bit over the half a tank what I doing wrong?
New exhaust
New o2 sensor
New catalytic converter
New injectors
New fuel pressure regulator
New fuel pump
New fuel filter
Did reset the car just sucking fuel..
Any more idea's as losing battle with the car just Goin to trash it can't afford much to keeping it running.. My kid is in Victoria while I am in SA so do need my car to visit her...
Ford Au Falcon 2001 Sr XD
FaceBook Fans Club Only for FORDS Ford Club On FaceBook!
allenford is offline   Reply With Quote Multi-Quote with this Post
Old 21-05-2019, 01:50 AM   #2
jstanovic
Default Re: Fuel miles on au2 sr
How much is half a tank? Have you actually measured how many litres you used for that half a tank? When you work out how many litres you used for the km then we can tell you if it's good or crappy!
Maybe the gauge is out?
jstanovic is offline   Reply With Quote Multi-Quote with this Post
Old 21-05-2019, 01:52 AM   #3
allenford
allenford's Avatar
The gauge is 100% correct lol I know that from experience running out of fuel when it was worse than it is now. (200ks a tank) .
My old au1 as my avatar did 270ks to half the tank
Old 21-05-2019, 02:01 AM   #4
allenford
allenford's Avatar
I might drive up the half.. 30 ks more then it might be 250ks to half..
I'm so confused I'm schizophrenia.. But put an old style Ford or Holden carbie in front of me I will make it run like new..
My old Ford falcon xe 250 crosflow on gas gets 506 ks city driving 600 petrol city which was great.. Just can't compute with the car tune
Old 21-05-2019, 08:08 AM   #5
Uncle_Ken
Next upgraded Mk1 Leopard
Uncle_Ken's Avatar
My old stock AU II 6 cyl would do at best 400 city ( less on LPG)
Uk
Old 21-05-2019, 08:27 AM   #6
How’s the paralytic converter? They are good until they aren’t, and it won’t throw an engine light to let you know.
Old 21-05-2019, 09:05 AM   #7
Peter B - CV8
What's your average speed reading ? Hard to get good fuel economy if you're stuck in stop/start traffic...
Peter B - CV8 is offline   Reply With Quote Multi-Quote with this Post
Old 21-05-2019, 09:49 AM   #8
allenford
allenford's Avatar
New catalytic converter mate basically new everything do with flow and fuel..
Moving fast not slow smoothly like before au1 should be the same as au2
Old 21-05-2019, 09:50 AM   #9
allenford
allenford's Avatar
Uk
That's what my lpg does.. But talking about petrol.. Which I aren't happy with.
Old 21-05-2019, 03:53 PM   #10
Maka
Au Falcon = Mr Reliable
Maka's Avatar
Check the inlet manifold bolts are tight & the gasket is in good condition & not cracked, good luck!
cheers, Maka
Old 21-05-2019, 04:34 PM   #11
xeeclipse
450 Klm around town on a minty is the norm. On factory lpg they run around the 18l per 100klm.
Monster engine and the old explorer 302W is just as endearing.
xeeclipse is offline   Reply With Quote Multi-Quote with this Post
Old 21-05-2019, 04:41 PM   #12
allenford
allenford's Avatar
I done 260ks it's on half a tank.. Petrol.
Lpg is not what I'm worried with that does 500ks but lpg slowly fading away and petrol is more strong pulling loads..
Old 21-05-2019, 04:45 PM   #13
allenford
allenford's Avatar
I did calculations getting 13.3/100ks so I should fill up then drive it like adult
And see how far to a tank
Old 21-05-2019, 08:52 PM   #14
XC50077
Drive'n Cruise'n Live'n
XC50077's Avatar
My AU2 SR, I am averaging around 10L/100 with a 50/50 mix of around town and 80kmh semi rural trips. Using BP95 now to help clean up the dirty fuel from the servo I used to frequent. Cheers.
XC50077 is offline   Reply With Quote Multi-Quote with this Post
Old 21-05-2019, 09:17 PM   #15
allenford
allenford's Avatar
99.9% me city driving.. Which sucks most of the time..
Old 21-05-2019, 09:53 PM   #16
jstanovic
13L/100km isn’t too bad for an AU around town, might get a bit better driving like a granny!!
Old 21-05-2019, 10:08 PM   #17
allenford
allenford's Avatar
I going to start this Thursday.. Give it a bath while it does it job
Old 22-05-2019, 12:23 AM   #18
allenford
allenford's Avatar
When first start up it will show 2.20 and reading rich.. But once warm this what shows
Old 23-05-2019, 04:50 PM   #19
falcon_bandit
13L city driving for a big 18 year old 6cyl barge is good!!
falcon_bandit is offline   Reply With Quote Multi-Quote with this Post
Old 24-05-2019, 01:50 PM   #20
Uncle_Ken
Uncle_Ken's Avatar
what about the THROTTLE POSITION SWITCH ?
UK
Old 25-05-2019, 10:17 PM   #21
allenford
allenford's Avatar
Got back from repair and other reset the au2 Sr..
Clean the o2 sensor again and boom now she's done 620 ks city driving.. (driving normal..)
598ks driving like a noob..
Well just needs a love.. Only problem is starts longer now
Old 25-05-2019, 10:38 PM   #22
xeeclipse
600km is a pipe dream, they do 450km at best around town.
Old 25-05-2019, 10:40 PM   #23
allenford
allenford's Avatar
That's why I stop whining about ks in the city.. Lmfao
Just need to talk about it
