Old 14-03-2019, 10:07 PM   #1
CitroŽnbender
DIY tragic
Default A Few AU Dash Panel Pictures
Mainly in case someone wonders how something should look, or how it goes together.
The steel brace tube or spine of it all.
Vacuum reservoir hidden in the steel brace tube.
The two halves of the lower section, and combined.
The top pad. White mess is a 2K acrylic glue made for spa repairs. Bonds nicely to ABS. Iíve also included a photo of where the centre braceback rod passes through the ducting, it was made with foam donut seals but a pair of closely abutted foam strips works as well.
Iíll add similar of the harness when thatís reinstated.
CitroŽnbender is offline   Reply With Quote Multi-Quote with this Post
Old 15-03-2019, 02:02 AM   #2
ronwest
All Bran = Regular Member
Default Re: A Few AU Dash Panel Pictures
You ought to get a hold of a mod and see if it can be added to the Tech Resources section.
ronwest is offline   Reply With Quote Multi-Quote with this Post
Old 15-03-2019, 03:51 PM   #3
speedzter
Thanks for the pics.
Can you tell me if the black hex fitting where the hose connects to the reservoir looks like it unscrews ?
I had the hose brake of below the black hex nut, and need to figure out how to re-attach ?
speedzter is offline   Reply With Quote Multi-Quote with this Post
Old 15-03-2019, 05:21 PM   #4
CitroŽnbender
DIY tragic
I pulled the barbed end of the black fitting, out of the clear piece to re-tape the three fixing clips. Didnít think to see if it was a thread the other end (gut feeling is, itís just another barb).
Old 15-03-2019, 06:36 PM   #5
Uncle_Ken
Next upgraded Mk1 Leopard
Uncle_Ken's Avatar
Tech Writer: Recognition for the technical writers of AFF - Issue reason: Writing tech articles Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Always putting some imput into the forums to help or make it a bit easier for others
Interesting info
UK
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
