Old 02-01-2019, 03:17 PM   #1
brucewarring
Default LS 2.0 Ltr Oxy sensors
Can anyone help please on the fuse chart it states fuse 32 HEGO 1 and 2 and fuse 33 HEGO 3and 4. Do I have 4 Oxy sensors , as I can only find I on the manual, also I think there is one after the cat, can anyone help with part numbers for the sensors please...thanks in advance Bruce
brucewarring is offline   Reply With Quote Multi-Quote with this Post
Old 03-01-2019, 10:57 AM   #2
russellw
Chairman & Administrator
russellw's Avatar
Default Re: LS 2.0 Ltr Oxy sensors
There are 2 on the 1.8/2.0L models and 4 on the 2.5L V6 which is why the fuses are there.
You are correct in saying there is one up and one downstream of the CAT.
The Walker replacement part numbers are EGO-223 (pre-CAT) and EGO-507 (post CAT).
Bosch part numbers are OXY1217 (pre-CAT) and OXY2237 (post CAT.
Russ
Observatio Facta Rotae
Old 03-01-2019, 01:49 PM   #3
brucewarring
Thanks for that Russ very helpful....have a great 2019....Bruce
Old 02-02-2019, 03:03 PM   #4
DeKa
I have part numbers for a 2009 LV with the 2.0 Duratec-HE engine. Drivetrain is the same but do check they’re correct for your car.
Upstream is 3M51-9F472-AC
Downstream is 3M51-9G444-AB
DeKa is offline   Reply With Quote Multi-Quote with this Post
Old 12-02-2019, 06:34 PM   #5
brucewarring
Thank you DeKa the ones that Russell sent were great and the correct ones...thank you for your trouble...Bruce
