Go Back   Australian Ford Forums > Site Sponsor Forums - In Alphabetical Order > Blue Power Racing Developments
Blue Power Racing Developments The home of Blue Power. Website Link
Old 07-04-2011, 07:14 PM   #1
BAWITHLOT
XB COUPE TOO!
BAWITHLOT's Avatar
Default DTC Downloading With Flash 2
I purchased a Flash 2 off you guys a year or 2 ago and finaly have a fault that I though I could fault find with it.
I have a ABS problem that causes the light to come on whilst driving. When I hook up the Flash 2 to down load the codes, I follow the instructions and get no codes (key off-key on etc).
How do I down load the code with a Flash2 when it seems that the fault resets when the car is turned off?
Is this setup only good for hard faults?
Any assistance would be appreciated.
Cheers,
BAWITHLOT is offline   Reply With Quote Multi-Quote with this Post
Old 08-04-2011, 08:14 AM   #2
StealthAu
Default Re: DTC Downloading With Flash 2
Fault codes are stored in the ecm and don't disappear when turning the car off then on again, if you are not getting any fault codes then none are being generated.
Old 08-04-2011, 09:21 AM   #3
Theo@BluePower
Bluepower
Theo@BluePower's Avatar
Please give me a call when you are next to your car with your flash tuner and i will run through a few things with you...
Bluepower website
47 Cooper Street Campbellfield Vic
03 9305 3000
Theo@BluePower is offline   Reply With Quote Multi-Quote with this Post
Old 08-04-2011, 03:31 PM   #4
BAWITHLOT
XB COUPE TOO!
BAWITHLOT's Avatar
Theo,
Thanks for your help. I presume that the Flash 3 would have only the same DTC functionality as the Flash 2.
Cheers,
