Old 11-07-2011, 06:16 PM   #1
nelsonian101
nelsonian101's Avatar
Default Territory Rear brake upgrade pad choice
I upgraded to the Rear rda 328mm ventilated rear slotted discs with territory calipers for my fgxr6t.
What is pad choice available now for circuit/road use?
Previously it was Ferodo only but not sure it was ds2500?
Are there any more available?
thanks.
FG XR6T ZF
350,000kms+
Road registered Lap record holder at Wakefield for any Ford or 2wd 4 door, of any make.....ever!!
Wakefield 1.07.4 SMP GP 1.48.1 Marulan 43.4 Winton 1.35.4
nelsonian101 is offline   Reply With Quote Multi-Quote with this Post
Old 12-07-2011, 03:02 PM   #2
FLOORED
Race Brakes Sydney
FLOORED's Avatar
Default Re: Territory Rear brake upgrade pad choice
thanks.
There are some endless pads but they are a bit pricey at $550 retail.The DS2500 is not made but we can get the Ferodo DS Performance for about $160 and same with the QFM A1RM pad for about $110.00 a set.
MATTHEW PEARCE
Phone 02 9609 1101
sales@racebrakessydney.com.au
www.racebrakessydney.com.au
Old 05-09-2012, 01:55 PM   #3
tkfd
tkfd's Avatar
thanks.
not sure if it has been covered, but can territory brakes fit rear of AU2 IRS?
tkfd is offline   Reply With Quote Multi-Quote with this Post
Old 06-09-2012, 09:44 AM   #4
FLOORED
Race Brakes Sydney
FLOORED's Avatar
They foul on the handbrake lever and the backing plate nut i am told this can be overcome although we have not looked into it.
MATTHEW PEARCE
Phone 02 9609 1101
Old 18-09-2012, 12:19 AM   #5
Silver'
T-Series Club Member Vic
Silver''s Avatar
Tech Writer: Recognition for the technical writers of AFF - Issue reason: Excellent write ups on AU technical issues.
This answers the question that I sent you via email this afternoon thanks Matt. Al.
TE2 #116
Build/Maintenance thread here.
www.fte.ford.com.au lives! 2001 2002
Add a T-series to the Registry HERE
Silver' is offline   Reply With Quote Multi-Quote with this Post
Old 18-09-2012, 08:00 PM   #6
Wolfinsheepsclothing
preying on lions
Wolfinsheepsclothing's Avatar
so does territory rear brakes fit fg falcons?
2014 FG2 Falcon XR6 luxury in Black, - New toy 2022 HD Lowrider S 124hp/136flb's
Wolfinsheepsclothing is offline   Reply With Quote Multi-Quote with this Post
Old 19-09-2012, 12:13 PM   #7
FLOORED
Race Brakes Sydney
FLOORED's Avatar
They will but the hoses may be different on some models.
MATTHEW PEARCE
Phone 02 9609 1101
Old 26-09-2012, 04:59 PM   #8
Silver'
Silver''s Avatar
I've just done this to my AU2 TE50. The only challenge is the backing plate, you need to reshape it around the new calipers and also fiddle around to get the clearance just so between the toe adjuster link at the rear and the new rotors. Oh, and 3mm spacers to pull the calipers into the centre of the car so they're centred with the rotors.
http://fordforums.com.au/showthread.php?t=11377772
Initial impression when driving are good, time will tell re: balance. I'm running OEM 'Premium' spec 329mm hardware at the front.
TE2 #116
