Old 30-07-2007, 01:23 PM   #1
hooper80
Default 1990 KF Laser Timing Belt?
I recently had my 1990 KF laser serviced and had the timing belt plus all attachments replaced last week. Since then the car has been making a noise like its buzzing/vibrating. It does it slightly when the car is cold but does it worse when the car is warm and at low and high speeds and only when accelerating. The engine mounts are fine and there is a little bit of a lag when accelerating.
Could something in the timing belt kit not have been fitted properly?
hooper80 is offline   Reply With Quote Multi-Quote with this Post
Old 30-07-2007, 07:18 PM   #2
dirty hands
Over Thinker
dirty hands's Avatar
take the car back to where the work was done ..to hard to tell from your description
may be plastic cover screw loose ,to belt noise ,timing pully or even tappets
lag on acceleration may be timing
may be possible where it has been timed to number 4 cyl and not number one TDC
My car goes Brumm Brumm
Old 04-08-2007, 12:42 AM   #3
mk2-71GTL
when the engine is running and making the buzzing and vibrating noise put your hand on the distributor and if you can feel a vibation replace the distributor
mk2-71GTL is offline   Reply With Quote Multi-Quote with this Post
