Old 20-02-2019, 07:13 PM   #1
Default Interior Clip - Where Does It Go?
This wee thing. It’s about a five cent coin in diameter.
I’ve got absolutely no recollection of where I removed it from - Alzheimer’s is obviously contagious.
Look forward to enlightenment.
Old 20-02-2019, 08:14 PM   #2
PG2
#neuteredlyfe
PG2's Avatar
Default Re: Interior Clip - Where Does It Go?
I'm going to take a guess here and say it is for one of the side boot liners.
PG2 is online now   Reply With Quote Multi-Quote with this Post
Old 20-02-2019, 08:23 PM   #3
Slight problem with that - it's a ute (charcoal XR6 interior, not leather).
Does the overhead console/sunglass holder thing normally just "float" on the headlining? Wondered if it could have been from that.
Old 20-02-2019, 08:28 PM   #4
PG2
#neuteredlyfe
PG2's Avatar
For the last three days I have pulled out the entire interior in my XR6 ute, cleaned it bit by bit and put it all back in and did not come across one of those clips.
Old 20-02-2019, 11:22 PM   #5
Three days? I'm still going; this one is filthy.
Old 21-02-2019, 02:17 PM   #6
FTe342
FTe342's Avatar
I have never seen one like that in an AU
T3 TL50 #147 Silhouette Auto ESS - Brembos - Last of 3 in T3 spec, only AUIII TL50 ever built -14.2 sec @ 98mph bog stock. Only customer ordered T3 TL50 built, only LWB sedan plated AUIII and the last performance enhanced LWB sedan built by Ford Aust.
AUII Fairlane Ghia Sportsman 5.0L in Blue Pearl
OWN THE ROAD
FTe342 is offline   Reply With Quote Multi-Quote with this Post
Old 23-02-2019, 12:55 PM   #7
Peter B - CV8
I was just working on my wife's Mazda 6 & came across almost the exact same clip. There were 3 of them used to retain the headlining across the rear windscreen area.
Peter B - CV8 is offline   Reply With Quote Multi-Quote with this Post
Old 04-03-2019, 01:23 PM   #8
Found another one, opposite side of the car, under the carpet. Interesting.
Old 04-03-2019, 11:15 PM   #9
Uncle_Ken
Next upgraded Mk1 Leopard
Uncle_Ken's Avatar
They are similar to ones I've seen in the engine bay. carpet clips?
UK
Old 04-03-2019, 11:32 PM   #10
Neither were pushed home, so I did wonder if they were discarded from an assembly used on other models and differently employed in the Falcon. The carpet definitely hasn't been up since January 2006, can't say before then.
