Old 06-10-2019, 12:44 PM   #61
JasonACT
Away on leave
Tech Writer: Recognition for the technical writers of AFF - Issue reason: Outstanding work on the FG ICC issues. Technical Contributor: For members who share their technical expertise. - Issue reason: The insane amount of work he has put into the Falcon FG ICC is unbelievable. He has shared everything he has done and made a great deal of it available to us all. He has definitely helped a great deal of us with no personal gains to himself.
Default Re: FORD technical service bulletin : ICC touch screen display
Ha ha! Yes, that's what I used to see Forscan try 6 times but fail each time.
It kicked me out of the FDIM settings when it failed. Then I tried the FPV setting and it did the same. That was on my original unit. Then I tried on the SAT NAV unit and FPV enable worked, but still couldn't set the VIN.
These devices check the settings, it's not a forced write.
An example is when the error code comes back on the CAN BUS for settings the VIN. Since setting the VIN is a multi packet CAN message, the error comes when it detects one of the VIN digits isn't "right". If you change the letters up front, you don't get to pass the rest of the packets because an error is returned early. If you change the last digit, the device accepts all packets up to that last one before giving you a response. The response seems to be error (in one packet) or success (seems to produce two packets).
JasonACT is offline   Reply With Quote Multi-Quote with this Post
Old 06-10-2019, 03:28 PM   #62
raceteam
Block 3 changes if the FDIM is from a Territory - goes to 0200.
raceteam is offline   Reply With Quote Multi-Quote with this Post
Old 06-10-2019, 07:09 PM   #63
JasonACT
Away on leave
Oh, ok. That's interesting. It might be the config profile loaded?
I've been playing with the ACMs today. Now that Forscan has "calibrated" the code (which BTW I don't see it sending my VIN into the unit - only a calculated 3 byte value each time you run the calibration routine) I can get it turned on and tuned to some AM station on the bench with my car's CAN-BUS recording. I can also adjust the volume with my spare steering wheel buttons. This is much better than soldering on some new wires and re-assembling it to fit in the car to test out.
It's nuts though! If I connect an AMP's input (I'm using a rear speaker for my tests) anywhere near the car-ground, then it gets all noisy. I was trying to attenuate the signal so there would be less hiss, with the drawback that you need to turn up the volume (doing so doesn't change the hiss level). So instead of a 40w system, it would be a 20w system but much better quality.. Sort of ready for some add-on 3rd party amp talked about previously. It's not happening though.
Confused about the quality of the MKI radio, I had a play with it too. Yep, nice and quiet. Cutting an AMP's leg and doing all my usual tests, no sound at all! The damn thing turns off the AMP when it's got nothing to output.
Turn the volume all the way down, AMP turns off. Turn it up just one notch, and the same hiss that the FG2 has can be heard. Since the screen in the MKI doesn't use the radio's ICC speaker inputs, I guess it thinks it can do that where the MK2 needs to keep it on all the time in case the ICC needs it. Sadly, there were no answers in the older model.
Old 06-10-2019, 07:27 PM   #64
JasonACT
Away on leave
Oh, I forgot to add.. In my tests, I've connected a switch (no, not the big one) so I can hear old vs new-mods. There is identical hiss when I traced the speaker line back to the largest chip on the circuit board (clearly a sound processor - which has 4 raw speaker outputs) and used the recommended 0.22uF cap. for the AMP vs the numerous components (and there are a lot) on the board. Identical sound too when the volume is turned up. The hiss is either in or before that sound processor micro-chip.
I even connected up another AMP to one of those outputs and there's hiss, along with ground noise. There is no fixing this unit, only working around it, if I can get the attenuation circuit working.
Old 06-10-2019, 07:38 PM   #65
raceteam
Have you tried looking at the ACM data blocks? A common improvement in the FG was to swap the wires going to the sub to reverse the phase. I wonder if that can be done with a config change.
Old 06-10-2019, 07:53 PM   #66
JasonACT
Away on leave
I did look, but there are 7 blocks (block 2 is the VIN) while blocks 1 and 3 are small, 4-7 are all quite large and wouldn't be easy to decipher. I recall Forscan only had 2 items you could adjust, Reset Centre Level and Sedan/Ute.
You're right though, there may be a switch for options that introduce the hiss?
Old 06-10-2019, 10:39 PM   #67
JasonACT
Away on leave
Success!
I found the Japanese PDF for the large chip (no I don't read Japanese!) but it had an example circuit that I could read. Like the Arduino, there's an audio ground that remains much quieter from the general ground...
The pin outs are in a different order to the AMP chip (AMP is on the right, audio chip is along the bottom):
Here are the first-in-line surface mount devices I'm going to hook into:
Solder the wires on:
Wires go to a bunch of resistors:
Resistors go to the capacitors which are connected to the cut AMP inputs:
The whole unit:
So I'm using a voltage divider (a couple of resistors) to attenuate the output from the audio processor (car AM/FM +inputs radio chip):
Four of these:
Output--->6.8Kohm--->0.22uF--->AMP-Input
AGround--2.7Kohm--^
I'm using the blue resistors (1% accuracy) so the end result doesn't need fader adjustment.
The hiss has been reduced to about 1/3 (maybe a bit more). When I listened to the radio before, I had the volume on about 13. Now I have to bring that up to about 20 (which doesn't increase the hiss).
I'll see how this goes tomorrow while driving, it's too late for a drive right now. Sitting in the carport though, it was so much better.
Old 07-10-2019, 11:37 AM   #68
JasonACT
Away on leave
Went for a drive, had the volume up at 24 - before when driving it was at around 16 (13 was when parked). Very clear sound, the mod has not introduced any extra noise. The volume goes up to 35, which I've never done before when music was playing, and now it is reasonably loud at that max level. Nothing earth shattering, I might have it that loud in rare circumstances (who am I kidding, I'm too old to want that).
But the hiss is so quiet now. Definitely less than 1/3 of the original noise. Very happy
Old 07-10-2019, 02:44 PM   #69
XRPete
XRPete's Avatar
Hi All,
Peter here, newbie to the forum .
Has anyone here managed to get there blank screen working again, when disconnecting the battery or pulling fuses out, doesn't work?
My radio and A/C is still working, of course, just no display.
I took my FG MKII ICC apart the other day, and it seems there is 2 parts to this FDIM.
1) the screen and touch panel
which is manufactured by AUO (PN:C080VW05 V1)
http://www.panelook.com/C080VW05%20V1_AUO_8_LCM_overview_14178.html
2) Controller Board
which is manufactured by SWS Australia Pty Ltd.
From what i could see, it may be this 2) controller board thats the issue. as when i inspected it, i did see a lot of residue on the board around the regulators and capacitors. - like when one of the blows.
Ill be pulling it apart again today, and ill upload some pictures for all of you.
Thanks
XRPete is offline   Reply With Quote Multi-Quote with this Post
Old 07-10-2019, 03:09 PM   #70
JasonACT
Away on leave
Do you have a multimeter? The red/black screen power wires should read 9v - which is where I'd look first.
Here are some picks of my working unit:
(Sorry, I'm just reassembling my car door - be back later.)
Old 07-10-2019, 03:41 PM   #71
JasonACT
Away on leave
Ok, car door's back in...
These are my notes on the FDIM:
According to the car ground, the black and red wires are ~11v & ~20v which gives 9v to power the screen.
The two devices on the left are on the small controller board, see first & third pictures. The one on the right is the large controller board's LF33 3.3v regulator, see last picture. I also measured quite a few of the pins connecting the two boards together. I stopped writing them down when I could see they were all the same, except pin 47 which had an odd mid-range voltage. "Thermal Shutdown" was shown to me on the screen after I took all these measurements, doesn't seem to have been any permanent issues though.
Old 07-10-2019, 04:01 PM   #72
XRPete
XRPete's Avatar
Hi Jason,
I just check the red/black wire to the LCD, and i am not receiving 9volts. :(
Also, what are you using to power the FDIM at your desk?
Old 07-10-2019, 04:05 PM   #73
JasonACT
Away on leave
2.0A - 12v adaptor from a "portable" hard disk.
You need the two boards connected together too, most of the power comes from the smaller board - even though the power inputs are on the larger one.
Old 07-10-2019, 05:24 PM   #74
XRPete
XRPete's Avatar
ok,so i did some bench tests, and without the red/black wire connected i get 2.5v and with it connected i get -0.5v.
Old 07-10-2019, 05:48 PM   #75
JasonACT
Away on leave
Bench testing requires a CAN BUS recording from a car being played into the unit, depending on the unit (firmware) it might turn on for 10 seconds when power is initially applied (after 20 seconds). My one from 2012 doesn't even do that, the one I've replaced mine with does - it's a 2014 model with newer firmware. What's yours?
If I didn't have the CAN BUS stuff, I would be testing the voltages while in the car.
You can see where the 20v and 11v are coming from, on the small circuit board. I don't think it's hard to measure those while in the car, as long as it's been unscrewed from the back cover.
It might be obvious from a picture, as you said, there's residue on yours?
Old 07-10-2019, 06:54 PM   #76
XRPete
XRPete's Avatar
I have a 2013 fg xr6, tested the voltage of the red/black wires from within the car, and still didnt get 9 volts.
Below is where i could see a lot of residue.
Old 07-10-2019, 07:31 PM   #77
JasonACT
Away on leave
The only thing I see which looks bad in that photo is the part-number on the 5 pin device. It could be heat damage that has faded it on yours (neither of mine look like that - I didn't take photos of my 2012 one because it looked exactly the same as the 2014 one except the GPS wasn't there).
It's a voltage regulator - low dropout model with 1.5A capability. Looks like it's an adjustable one so I don't know the voltage it's meant to have. I'll have to take my readings again, based on the schematics I downloaded, the only thing mine is doing is accepting the 12v input voltage. The enable pin is telling it not to output the regulated power. I'm almost certain the screen was displaying when I took the readings, so I don't know what it's being used for...
I'll come back with any extra info I can find.
Old 07-10-2019, 07:51 PM   #78
JasonACT
Away on leave
Mine is definitely "off" via the enable pin when the screen is running. I'm thinking that one is for the night time LEDs on the buttons circuit board.
Do you have 11v & 20v on the component next to it?
Old 07-10-2019, 08:12 PM   #79
JasonACT
Away on leave
This one is an 8v voltage regulator:
The pin with the white dot should read as 8 volts. It's only a 100mA output regulator - so it's a candidate for burning up. Part number LE80 (LE80CD-TR for example).
Old 07-10-2019, 11:30 PM   #80
XRPete
XRPete's Avatar
i checked LE80 and i am receiving mv all round.
on Q15N06-42L (the one with the middle pin missing) top pin im receiving 5.6v and bottom pin im receiving 11.89v. i might have popped this mosfet during my last test too... see attached.
I powered the screen separately using a 9v battery and then powered the unit, and noticed lines across the screen, similar to the image below.
Old 07-10-2019, 11:55 PM   #81
JasonACT
Away on leave
Oooh, that black dot wasn't there before. You will be up for a new mosfet then (I'm glad you identified what it was too - I hadn't mentioned it before because it's not a regulator, and it didn't change values for me when the screen was on or off - so whatever it's switching isn't the screen directly).
I'll do some more tracing tomorrow after work, to find where the +20v is generated from. That would seem to be the "thing" for the screen to light up (at least).
I'm not quite sure what you mean by "mv all round"?
Old 08-10-2019, 12:09 AM   #82
JasonACT
Away on leave
(The lines on the LCD may just be because there's no common ground, with the foreign 9v supply. Throws me though, using the ~12v positive as a ground, some engineer somewhere is proud of themselves, I'm sure.)
Old 08-10-2019, 12:10 AM   #83
XRPete
XRPete's Avatar
sorry, when i tested the LE80 chip, i didnt receive 8volts, just millivolts at all pins..
so as i was testing voltages on the 5 pin chip, i accidentally touched 2 of the pins at the same time, and popped a hole in the mosfet opposite to it (the 3 pin one) as you can see in the image.
But i think you may be onto something, with that 8 pin chip as i wasnt receiving 8v from that either....
I think these guys in the link below have worked out what the problem is with these screens and exchanging them, as they are charging $716 for an exchange screen. so i assume that they fix your old one, and give you another repaired one they have fixed previously.
https://www.aslautomedia.com.au/falc...creen-exchange
Old 08-10-2019, 12:16 AM   #84
XRPete
XRPete's Avatar
ok so the red/black wires are just to power the back-light of the LCD.
i noticed these lines as i had angled the LCD around - no back-light illumination.
I thought to manually power the back-light with a 9v volt battery just to illuminate what the LCD was producing.
Whenever id pull the power from the FDIM but leave the power to the back-light on, the lines would disappear.
So these lines are definitely something that the board is producing.
Old 08-10-2019, 12:19 AM   #85
JasonACT
Away on leave
Yeah, that's what the OP did. He's happy now, so I'm happy for him too. I've kind of stolen his thread though
The voltage input to the LE80 is the +12v input of the car - so I'm surprised that isn't getting through any more. There's a choke on the larger board, maybe that's gone? Hard to believe though? What were the circumstances of your screen dying? (Sorry, I'm going to have to bail - got work tomorrow.)
Old 08-10-2019, 12:25 AM   #86
JasonACT
Away on leave
The board still may need the +20v to produce the correct screen output (explains why the engineer did all this). So it's still a good possibility there's a simple fix (not a $700 one).
Old 08-10-2019, 12:35 AM   #87
XRPete
XRPete's Avatar
Well, I really don’t know why my screen just died.
I sent to work last Wednesday and it was working fine, I jump in my car to go home at the end of the day and nothing, just blank screen. It was a hot day though here in SA, so it could of been that maybe.
I called Zooper! as I have a premium protection warranty plan with them because I only bought this car in February and they won’t cover it. They had advised me that ford should be exchanging them free of charge, being an apparent “common fault”. I called 2 ford dealers and asked to speak to there service department to which I was advised they were busy and would call me back, they never did.
So I took the bob the builder approach hahaha
Old 08-10-2019, 06:08 PM   #88
JasonACT
Away on leave
Ok, this shows damage to the physical circuit board, can you re-check it?
The 11.89v comes from pin 5 on the large connector, it goes to the MOSFET and the voltage regulator's V-In (the one I think runs the front button LEDs). It also directly goes to pin 8 on the LE80 (the one directly across from pin 1, to the right). If that is only measuring mv, then the board has suffered a trace meltdown. The trace is in the layers of the circuit board (top and bottom of this board are generally grounded with very few traces).
I've seen it before, but really, it shouldn't happen with such low value components - which is why I'm asking you to re-check. You "could" solder in a thin strand of wire (in case it's going to blow like a fuse) to see if you can get the 8v working again? I don't want to suggest bad things to do, but unless you start pulling out components (that show a problem) and replace them - this is what I might do (to be honest, I thought about your 9v battery idea, but wasn't going to mention it because of this very concern).
Since this part isn't working, we really need to get it sorted first. The 8v may supply voltage to the other bits which cascade through the unit - and this one is "up front" because the 2 others are (/were, poor MOSFET) running off the 12v which is working.
Old 08-10-2019, 06:16 PM   #89
JasonACT
Away on leave
I had another win this afternoon.. The SAT NAV aerial arrived in the mail. This was the last component I needed to put back the last cover which has been off since last Friday:
Old 08-10-2019, 06:54 PM   #90
XRPete
XRPete's Avatar
Just at work, at the moment. I’ll check soon.
I had a small win today as well, sort of.
I local wrecker as a few screens for sale ($365) from a SZ Territory, which looks identical to my screen, but not sure on the following and couldn’t test their screen
as they have a “you break you pay” policy.
I’m also worried that this could be already dead (even though they are saying it working) an I’m stuck with the bill. As the people are saying in this forum that their screens have died just from disconnecting the battery.
1) Are the SZ screens compatible?
2) do they require reprogramming of any kind to work in a different car?
