Old 24-10-2010, 04:04 PM   #541
schrammy
Default te50 Window wont work
Hey guys
My passanger window wont go up, it went down now it wont work? thought it may be the switch as this is a problem but i cant put it up with the driver controls either?
Any ideas?
Ben
schrammy is offline   Reply With Quote Multi-Quote with this Post
Old 25-10-2010, 09:11 AM   #542
lohnro
lohnro
If neither switch will move the window it is probably the motor. I have replaced mine. You have to buy the whole assembly from a second hand parts place. Not expensive considering what it does. It is tricky to remove and install but not hard. Good idea to lubricate the runners with silicon spray to ease the tension on the motor. Good luck
lohnro is offline   Reply With Quote Multi-Quote with this Post
Old 05-01-2011, 03:34 PM   #543
Skeg37
Default Park brake light fading
My park brake light is fading on and off while idling. I know the handbrake needs adjusting and probably due for a new set of pads, could this be the problem.
Skeg37 is offline   Reply With Quote Multi-Quote with this Post
Old 06-01-2011, 06:02 PM   #544
lohnro
lohnro
I reckon the switch under the foot pedal needs changing. There is nothing else in the circuit that will make it intermittent.
Old 02-02-2011, 01:41 PM   #545
XYGTHO
FORD FREAK
XYGTHO's Avatar
Originally Posted by george7
Did the production of the series III get rid of most of these common problems with the SI and II
Also qurious if this is the case.
JUST LOVE THAT V8 SOUND, RUMBLE, MUSIC!
XYGTHO is offline   Reply With Quote Multi-Quote with this Post
Old 02-02-2011, 06:08 PM   #546
AMB
Technical Contributor: For members who share their technical expertise. - Issue reason: Always has a helpful answer in the technical sections, wether it's giving information on a simple diagnosis with a small issue, Helping someone fix their car if they are stuck on removing/installing something, or just need information on what works how.
The park brake switch (located on the lever) is wired directly to earth near the lever. Probably either the earth is bad, or the switch itself has bad/dirty contacts.
AMB is offline   Reply With Quote Multi-Quote with this Post
Old 14-03-2011, 10:59 PM   #547
shayne93
66 Mustang
shayne93's Avatar
Originally Posted by tags84
mate this happened to me 3 times in my EL that i owned for 12months! then i got my AU and 2 months later it happened in that so i bought 2 switches....... and a bloody of a thing to change, upside down the the foot well lol
I've done 2 in 2 Au's your dead right, dog of a job!
shayne93 is offline   Reply With Quote Multi-Quote with this Post
Old 20-05-2011, 02:58 PM   #548
BJB
BJB's Avatar
Default Re: Common Problems with the AU??
Drivers door lock on AU3. Sometimes it will lock with the key, others it refuses to lock. Up down, back and forwards, sometimes it works sometimes it won't. Are the door lock actuators a common problem. Fix? Cost?
The remote isn't working either.
BJB is offline   Reply With Quote Multi-Quote with this Post
Old 20-05-2011, 03:00 PM   #549
Mechan1k
Mechan1k's Avatar
Common ... If buying new ... you need to get a B-series actuator ... with an AU jump-loom separate.
can get them from wreckers for cheaper ... but it could fail the next day ... or last for years.
New price from Ford about $130-ish
Used price ... not sure. Ask FTG Autosalvage (site sponsor) ... the guys will be able to help you out.
Old 24-05-2011, 01:10 PM   #550
Swedishmoose
Hi there,
I was wondering if it is normal that I can just pull the automatic gear lever from "neutral" into "drive" and from "drive" into "3" without pressing the button.
I have to use the release button to put the lever from "neutral" into "reverse" and from "3" to "2" and from "2" to "1" which makes sense to me.
And another small thing...
is it normal that only the driver"s sun visor mirror has a sliding cover and the sun visor on the passenger side has just got a plain mirror without a sliding cover ?
thanks for any information
cheers
The Moose
Swedishmoose is offline   Reply With Quote Multi-Quote with this Post
Old 24-05-2011, 01:29 PM   #551
divine_afg
Extreme_Custom
divine_afg's Avatar
Originally Posted by Swedishmoose
Hi there,
cheers
The Moose
All is Well.... Enjoy. Drivers sun visor has cover to protect your eyes against any reflections if you were using it. Drivers are are More important than Passengers lol.
If You Think AU Are Ugly ! Check my X Out.........
Loved by one ... Admired by many ... Envied by most !
RIP - F6
divine_afg is offline   Reply With Quote Multi-Quote with this Post
Old 25-05-2011, 06:57 AM   #552
BJB
BJB's Avatar
Our Series 3 diff got noisy just before 60K and got worse .Ford didn't want to know about it as it was out of warranty and we haven't fixed it as yet. 117K now.
Old 25-05-2011, 07:30 PM   #553
Beer Baron
I bought mine with a noisy diff at 180k, Now 250k and still the same.
AU XLS.
Beer Baron is offline   Reply With Quote Multi-Quote with this Post
Old 13-06-2011, 09:53 PM   #554
Swedishmoose
Thanks mate....
I was just wondering about the gear lever....
Thanks for replying
passengers have to sit down, buckle up and shut up lol.....or walk
Old 14-06-2011, 10:04 AM   #555
divine_afg
Extreme_Custom
divine_afg's Avatar
Thanks mate....
Thanks for replying
I loved that fact that you could down shift without using the release button, made overtaking easier. One more think to add on the sunvisor thing - cost cutting
RIP - F6
Old 13-07-2011, 04:38 PM   #556
roycey92
my diff has been leaking for about 6 years on my AU 3 ute and i havent even checked it once it likes to do the old clunk but
roycey92 is offline   Reply With Quote Multi-Quote with this Post
Old 30-07-2011, 11:49 PM   #557
DaleBro65
Hey Guy's, just wandering if anyone knows or has an idea about this. Driving my AU111 XR8 the other day and it was down to 65kms left till empty so I stopped at the first servo I saw and filled it up and it runs on 98octane. Hoped in it and drove about half a km and it stopped dead in the middle of the road and wouldn't start for about 5 mins. After 5mins it started and hasn't missed a beat yet. Any ideas what could be wrong?... Trying to put the wife at ease before she drives it again. Cheers
DaleBro65 is offline   Reply With Quote Multi-Quote with this Post
Old 06-08-2011, 09:18 PM   #558
falcon75
Ford Fan
Originally Posted by sbutler
I had a ripper one day! the left window wouldn't work it was stuck down, so I rang FTe service and the guy said, "get this" press the window switch up & down 31 yes 31 times, that will fix it!!! yeah right :******1: anyway I did this, and bugger me on the 31st time the bloody thing worked!! : Beats the hell outta me. I dont know if anyone else has had this..
Yer we had the same bloody problem with the same solution
falcon75 is offline   Reply With Quote Multi-Quote with this Post
Old 06-08-2011, 09:40 PM   #559
falcon75
Ford Fan
Originally Posted by Auslandau
Have an AU 1 guia and only problem has been the windows sticking, as previously has said. But the rear diff is starting to make the 'Taxi whine' and is a bit annoying, and at only 90000 km but apart from that is the best Ford I have had for lack of problems.......touch wood!!!! With the VCT, it does hoon along a bit as well :voldar02:
The wagon is an AU 11 dead standard and just came back from a quick trip to N.T. and back to Melb, with again no probs. Windows are bit annoying in that one too!
Ive got an AUIII XR that has developed the same sound from the diff at 75000km. Have you any idea what it is?
Old 06-08-2011, 09:43 PM   #560
falcon75
Ford Fan
Angry Re: Common Problems with the AU??
Originally Posted by Casper
Based on some suggestions from Bucknaked, this thread is to share your experiances with problems that have occured with your AU.
Be them common (like the shock mounts on the IRS models) or not so common (a dead MAP sensor making the car run rich and lose power), share it all here
The problem, the solution, the cost.
This is not a "I have a problem, need advice" thread, it is purely for those that have had a problem, found the cause and got it sorted. These experiances may save us all a lot of time, headaches and money.
Yer my AUIII XR had its shocker mount come through the leather back seat (fixed under warranty), was not happy when my son usually sits there. Ford said it was a common problem.
Old 07-08-2011, 05:10 PM   #561
Venomous1
5.0 means business
Venomous1's Avatar
Possibly some dirt in the tank shouldn't be a problem now.
Windsor V8 Enthusiast!
Turbo Barra Lover!
Venomous1 is offline   Reply With Quote Multi-Quote with this Post
Old 07-08-2011, 08:36 PM   #562
FTe342
FTe342's Avatar
When filling only round up to the next $ after the first click off. If you keep topping it till no more fits in you end up with fuel in the purge canister and causes it to cut out
T3 TL50 #147 Silhouette Auto ESS - Brembos - Last of 3 in T3 spec, only AUIII TL50 ever built -14.2 sec @ 98mph bog stock. Only customer ordered T3 TL50 built, only LWB sedan plated AUIII and the last performance enhanced LWB sedan built by Ford Aust.
AUII Fairlane Ghia Sportsman 5.0L in Blue Pearl
OWN THE ROAD
FTe342 is offline   Reply With Quote Multi-Quote with this Post
Old 05-09-2011, 09:20 PM   #563
Wolfghost
Wolfghost's Avatar
Au2 xr8 2001 model was missing at idle, not so noticable under revs. Had efi dude out to repair problem, said it was computer and afs sensor so soughted new afs and sent comp away for repair, unable to fault old computer, sent back, fitted parts same thing,, then said was O2 sensors, replaced them, same dilemma. didnt call him back. Sent car to new mechanic. explained problem, missing and a vacuum leak i cannot find.
After test they said i had a coil issue, said i replaced coils twice in 2 months wasted another 1000 dollars on there recommendation, and the idiot proceeded to tell me, that I dont have a CAMSHAFT SYNCHRONIZER (or sensor) because i have pushrods. I wont tell you what i thought and said. took home noticed harmonic balancer had slipped, replaced, still same issue.Camshaft synronizer is about to be replaced.
Replaced parts list for a miss
3 sets coil packs
2 sets leads
2 sets plugs
1 computer
1 air flow sensor
2 O2 sensors
1 Harmonic Balancer
full set intake gaskets, valley, planem, throttle body etc
plus labour at 104.00 p/h ( the joys of a mining town price but not working at a mine)
and annoying the wife by having to use her (corolla). been 8 weeks now and looks like it will be ongoing until i can find someone who is capable of diagnosing. will let you know when its running as it should
Wolfghost is offline   Reply With Quote Multi-Quote with this Post
Old 09-09-2011, 07:54 PM   #564
Skeg37
VEHICLE - AU sedan 98 model XR6
PROBLEM - brown Frothy Sludge In Radiator Overflow
DIAGNOSIS - Cracked Transmission Cooler Pipe Allowing Transmission Oil To Leak Into Radiator.
SOLUTION - Transmission Cooler Pipe Replacement Kit Or New Radiator (chose New Radiator)
COST - $350 For Radiator And $32 For Top Up Transmission Fluid
RESULT- Drives Beautifully And Cool......
Old 10-09-2011, 10:54 AM   #565
BJB
BJB's Avatar
AU111 SR. Coolant leak around the thermostat housing. Fixed twice under warranty.
Noisy diff just prior to 60K and still there. Ford refused to fix it.
Rust in lower boot lid ( possible leak of water from factory spoiler.)
Drivers door locking mechanism failing.
Power windows have had their moments but still work.
Drives good, auto and engine are fine.
Not buying a new Ford again as Ford Warranty Policy is questionable.
"If your wife needs a good Falcon, send her down and we'll dicker" - Early 60's Ford salesman.
Old 10-09-2011, 11:39 AM   #566
T3man
T3man's Avatar
Not really questionable mate - just downright useless in most cases. It's simply not worth the stress it causes having them fix something over and over ... and it never gets fixed anyhow. Nowadays I just buy second hand and with the money I save I can afford to throw it into any repairs necessary and pay the right people the right money to have it done .. well ... right.
Old 11-09-2011, 12:41 PM   #567
BJB
BJB's Avatar
I heard that Ford Warranty issues are outsourced to a group commissioned to filter the claims. I guess if they can keep the claims down then they get better bonuses. Urban myth , not sure. What they don't realise is that reputations ruin companies, and Ford Australia are struggling to sell the Falcon at the moment and no wonder. If you have a faulty product , then deal with it. Good service will get people back to the show rooms. My cl;aim was rejected because I didn't have the car serviced enough with them. The diff is noisy but it has been this way for over 70K now so it probably won't break too soon, still who sells cars these days with diffs that develop a noise at under 60 K. We don't tow, it is driven sensibly. Another thing, my work had XR 8's that were always being faulted for various issues. The local dealer would just treat as a regular customer and try and book us in. Hell no, emergency vehicle mate. The local Holden dealer would move hell and high water to accommodate us and therefore we prefer the Lion over the Blue oval. Downtime is a drag.
Ford Aus wrote to me later as a valued customer to see if I would be interested in the FG series they were releasing. You have to be joking was the answer.
Old 16-11-2011, 06:49 PM   #568
Skeg37
I have an Au XR6 1998 Adaptive shift auto. Once my car gets warm it stalls as soon as I put it in gear. I have been told it is a solenoid in the auto transmission and will cost around $450. Does this sound right? Is there any other solutions/suggestions?
Old 16-11-2011, 11:18 PM   #569
Wolfghost
Wolfghost's Avatar
Finally found the problem 2 months later, poor falcon been parked up for months, one broken valve spring, they are all being replaced at we speak
and should have me car back this weekend.
Old 16-11-2011, 11:53 PM   #570
Beer Baron
Ask what solenoid it is. There is a big price different between the solenoids. Doesn't sound outrageous though.
AU XLS.
