31-08-2013, 07:46 PM | #451 | ||
Put the leather interior out of my EL Ghia, into my ED XR6..... Sooo comfy!
Current-2013 SR5 Hilux TJM bullbar and bashplates, 2" lift, spotties and awesome fuel economy Previous- 93 ED XR6 5 speed, dumped and exhaust 97 EL Ghia auto luxury, on it's guts 94 ED Futura 5 speed tucking with exhaust 97 XH ute, 5 speed with P-Plate spec exhaust 98 AU1 forte AU gheyness |
31-08-2013, 07:55 PM | #452 | ||
normality is boring
I took the nf/df cluster, console rear light, chrome shifter shaft, nf black height adjustable front seat belts and ef black rear seat belts from my old el wagon and fitted them to my new el wagon. Also fitted a custom rear bar and did a cooling system flush and de-badged the same car.
Then prepped, primed, sanded and painted more parts for my wifes wagon
Factory v8 with turbonetics 67mm turbo, haltech ecu, aeromotive and raceworks fuel system, cobra intake and a few custom bits thrown in |
31-08-2013, 09:38 PM | #453 | ||
Bare metalled the LHR quarter panel.
The lazy ***** who repaired and painted it before I got it couldn't be bothered panel beating - just filled low points with bog; over half an inch thick in places! I tapped it out, heat shrunk one area and now it will only need a skim in a couple of places. |
31-08-2013, 09:46 PM | #454 | ||
Only a small job but replaced the adaptive shift badge on the shifter plate, really bugged me that it was missing along with the ticky badges on the front guards.
01-09-2013, 11:50 PM | #455 | ||
Futura
Found a noise that'd been driving me spare, and fixed it!
I used to have a few main noises from the back of the car while driving on bumpy roads. Since I have almost nothing in the boot (no carpet, boot lining, nothing until I finish some rust work) any noises from that end are amplified - which gives me the chance to tackle one at a time. I've gone through a loose badge on the bootlid, a small squeak around the boot lock, a wire bundle on the left side indicator/brake light housing clattering against the side of the quarter panel... and this infernal *clunk* that wouldn't show up on all bumps, but enough to leave me with one eyelid twitching. Turned out to be one of the boot springs - on the passenger side where the torsion spring exits its holder was a rust mark up higher than the spring turns when the boot was opened and closed. I think with regular vibration, the spring would creep up the notch holding it, then suddenly click back down where it sat before when I'd go over a larger bump. One single drop of oil (on a part of the chassis that looked so clean I doubt it'd ever had a spray of WD40 let alone lubrication) appears to have fixed it - there's no longer enough grip for the spring to creep up. A quick zip around town had no clunks whatsoever. I can stop twitching now |
02-09-2013, 12:21 AM | #456 | ||
I replaced the front OEM Rotors, pads and brake lines with DBA 4000 rotors, Brembo pads and Goodridge braided lines thanks to Race brakes Sydney.
Octane BFII XR6 Turbo manual sedan. SOLD 2014 BMW S1000R 2006 Toyota Landcruiser GXL 1HD-FTE |
02-09-2013, 12:58 AM | #457 | ||
Got very upset with it after noticing a 'flapping' noise ten minutes from home, having it stall at the top of the driveway and when I finally get it started it decides not to hold idle and dies straight away. Once I finally get it started and idling kinda normal, I start to hear a shocking knocking noise coming from the engine, praying to God that it's only the belt tensioner which I will replace tomorrow; if not then I'm going to burn it because I can't handle all the problems it's throwing me
2003 XR6 Turbo
04-09-2013, 08:53 PM | #458 | ||
Super Happy Fun Slide
1. De-badged the boot and side skirts on the BF because I needed to do something because bored.
2. Looked around again for new race car project to fill the space that was left when I sold my Line. Results for 1. Success Results for 2. Failure Being forced to build to a budget is proving to be a royal pain in the proverbial, LOL, the Minister of War and Finances was a bit upset that my last toy cost around 80k for 4 years of racing and has now limited my budget to 2/5 of not much........ Stupid budget............................................... Last edited by MLR; 04-09-2013 at 09:01 PM. |
04-09-2013, 11:11 PM | #459 | ||
FG XR50 TURBO
restored my momo wheel, the shoe dye i apllied awhile ago was too shiny
04-09-2013, 11:42 PM | #460 | ||
Ordered some parts today
Fuel pump for 1939 Willys sedan and Stop / Tail light for 1952 Willys Jeep Station Wagon. Gunna get some photos on here soon. They both belong to my Father-in-law - he's unfortunately got alziemers now so We are getting the cars road worthy again - they're almost there! my wife's mum wants them sold - I don't!!! let's see who wins
476 EF XR6 Wagons - 198 were Manual 2010 Anniversary XR50 in Sunburst - 6spd Manual My Gallery Photos Here |
04-09-2013, 11:46 PM | #461 | ||
Sold it... :(
05-09-2013, 08:17 AM | #462 | ||
Put an O2 sensor on..see if that helps my economy...
07-09-2013, 04:06 PM | #463 | ||
Futura
Kept at the general maintenance on less exciting parts. Rear passenger door this time - lithium grease in window raiser, cleaned out sticky grease on the door lock mechanism and re-oiled/greased the springs and links. Also, two bolts holding in the winder were a touch loose. Quieter now, much quieter, not to mention easier to open.
Just like a bought one! Also, some git pelted the car with ice-cream cones and eggs last night. Washed that off. |
07-09-2013, 04:08 PM | #464 | ||
Moved it - so I could clean up!
The bloody fairies didn't turn up! :( |
07-09-2013, 04:21 PM | #465 | ||
Gazza!
Pulled the coil cover off, saw the vcp phaser seals are still leaking, put the cover back on.
2005 Silhouette BA Fairlane Ghia Turbo 2017 AFF Nats best burnout chariot ZF 6spd converted, GTX3582R, plazmaman and xforce goodies, tuned by BluePower Racing Developments. 11.79 @ 122mph RIP 2006 - 2017
07-09-2013, 09:18 PM | #467 | ||
Chucked some transmax z oil in the t56 in the xr8 today,shifts like butter
Gave the underside of the motor and gearbox a good degrease and pressure clean to help finding leaks down the track. Happy with that effort today |
07-09-2013, 09:31 PM | #468 | ||
Today I noticed one of the globes in the number plate lights on my AU ute had blown so I went to replace it only to have the clip on the light assembly fall apart. I cleaned it and found it had been broken in the past and the previous owner attempted to fix it with silicone. I'm gonna have to find a replacement light assembly tomorrow.
My Ride... 2005 BA2 XR6 Magnet Ute. |
08-09-2013, 01:53 PM | #469 | ||
2003 BA Falcon XT
2003 BA Ford Falcon XT IMPCO LPG Vapour Injection. DETAILING Meguiar's NXT Car Wash Collonite #845 Insulator Wax Bowden's Own Happy Ending & Fully Slick Chemtech CT-18 Truck Wash (Wheels & Chassis) Bowden's Own Wheely Clean & Tyre Sheen Bowden's Own Three Way Paint Decontamination Spray OILS AND FILTERS Nulon Full Synthetic 10w-40 Nulon Long Life Coolant Ryco Oil & Air Filters My Instagram Account: @ba_falcon2003
08-09-2013, 02:12 PM | #470 | ||
Clutch Cable Killer
I went for a cruise just me and the beast up the coast and took some pics
What I should be doing is washing her and getting rid of some swirl marks
Matthew 1997 Manual EL XR6 in Heritage Green Extractors and 2.5" exhaust- - 16" Tickford Wheels - Full EL XR bodykit - COYO73 Plates HID projectors, lowered on King SL and Koni Shocks. Daily - 2002 AUIII SR Stock as she comes. Coyote's EL XR6 ^^Click Me^^ 15.132@ 91.51 MPH Photos by Me https://www.facebook.com/PhotosByMatthewWylie |
08-09-2013, 02:18 PM | #471 | ||
Pulled the engine out of my old rodeo 4WD ute and stripped it down. Tomorrow I am going to buy it a set of new pistons and get it rebored.
Don't try and teach a pig to sing, it just wastes your time and annoys the pig.
08-09-2013, 09:13 PM | #472 | ||
FG XR50 TURBO
08-09-2013, 10:33 PM | #473 | ||
Clutch Cable Killer
Thanks mate, yeah mine is good as a daily but I wish I could retire it to weekend duties and work on it. Stone chips are the worst haha
10-09-2013, 12:09 AM | #474 | ||
Lucifer's Angel
Tightened up the rear sway bar that had come loose on one end, and cleaned the throttle body (which was long overdue really).
Happy the occasional stuttering and the annoying clunk in the left rear are gone!!
SINISTER BA XR6 Blueprint, manual, 4490's, Redback 2.5" dual exhaust, BA Typhoon rims, tint, fog light covers, BF tailights, blue illuminated window switches, Ghia bootlid carpet, lower grille, FPV door spears, steering wheel & interior bits, XR6T + F6 intake, K&N filter, Typhoon spoiler, tuned, sway bars, custom angel eyes & plates..YUM!
If there's one thing guys in Holdens hate more than being beaten by a Ford... It's being beaten by a girl driving a Ford |
13-09-2013, 06:39 PM | #475 | ||
Oil and Filter change
Boss powaaaa |
13-09-2013, 08:22 PM | #476 | ||
New gas struts for the bonnet and hardcover, so sick of having to hold the hardcover up while trying to get something out of the tray haha
FG XR6T Ute
300rwkw |
14-09-2013, 11:26 PM | #477 | ||
Fitted a 2.5'' catback exhaust today, to say I was pleased with the results would be an understatement larger than my grin when I first started her up
14-09-2013, 11:38 PM | #478 | ||
Formerly lil_lincoln
removed 20% window tint off the fairmont ghia i sold my brother inlaw, stupid roadworthy rules.
15-09-2013, 12:06 AM | #479 | ||
Lacking Imagination
Installed Oil Cooler & did an Oil Change
My 11 Second AU Fairlane 364w | 225cc CNC | ---/---@0.050 | Morrison Motorsport ITB Manifold | MoTeC M150 (Engine Control) | PCS TCM-2800 (Trans Control) | 6800rpm Stall | 4R75W |
15-09-2013, 12:40 AM | #480 | ||
Well not just today but Thursday I picked it up from the mechanics after having a new engine and turbo fitted.
Today, I finally got around to fully replacing the roofling, interior lights and tyres now I just need to give her a wash and polish and I'll be happy; well once I figure out how to polish it properly due to the deep scratches from the last owner.
2003 XR6 Turbo
