10-03-2012, 02:44 PM | #391 | ||
Thailand Specials
I got a rear camber kit too, easy job as well?
10-03-2012, 09:28 PM | #392 | ||
The camber kit is a great idea too. Your rear will love you for it! I had Pedders put my camber kit in, then do the wheel alignment.
10-03-2012, 11:15 PM | #393 | |||
Thailand Specials
13-03-2012, 05:47 PM | #394 | ||
Thailand Specials
I've got some issues already, I think the tyre is rubbing on the guard somewhere, as I get an odd vibration.
I also think I've done some damage to the car, I went over a speed hump and hit something under the car, about 5 minutes later the speedo started acting up, then the ABS and traction control lights have come on. I'm guessing wheel speed sensor for the ABS, traction control and speedo to be playing up. I've also only got about 10cm clearance from the front tyres to the guard, is that right? FML. Last edited by Franco Cozzo; 13-03-2012 at 05:59 PM. |
17-03-2012, 12:10 PM | #395 | ||
Well the Goodyear NCT oem tyres on the 2008 TDCI-the last 2 gave up the ghost on Thursday at 84000kms. I was doing 110km/hr in the fast lane when the tyre noise level developed a loud rumble-got her over to the breakdown lane and the tyre was smoking.11 square holes around the rim of the tyre truly life expired.
Now have 4 toyo teo plus all around and the car for the first time in its life is substantiaaly quieter. I hated those noisy Goodyears! |
17-03-2012, 01:28 PM | #396 | ||
Thailand Specials
We found the issue, I smashed the wires off the wheel speed sensor, simple solder job but still wasn't too happy about it. I have to be more careful.
Also the front right OEM tyre is rooted, badly, the far inside edge is basically bald and has chunks out of it. I've got a set of 18" Mondeo XR5 wheels coming for it on monday. |
17-03-2012, 01:36 PM | #397 | ||
aH YA DID ITon purpose to getta rid of ya goodyears.
Arent you worried it will ride like a dray with 18'' wheels on?? |
17-03-2012, 01:38 PM | #398 | |||
17-03-2012, 01:44 PM | #399 | |||
Thailand Specials
17-03-2012, 10:52 PM | #400 | ||
18"s aren't too bad on eibach springs I put the wheels on before the springs and wanted to kill myself every day, but the springs made the ride 100x better, so you'll have no worries, a little rougher but still liveable.
2010 LV Focus LX Titanium Grey - K&N Apollo CAI - 2" Cat-back Exhaust -18" Black with machined front RS rims - DRL/Halo Headlights - Eibach prokit springs - Front Strut Brace - Black XR5 Spoiler Plans: Whiteline Rear Sway bar |
18-03-2012, 08:55 PM | #401 | |||
Thailand Specials
I really need a wheel alignment and the rear camber kit done, because the rear wheels are noticably off camber, to the point where you can easily pick it looking from behind the car, the rear wheels are leaning on their inside corner. |
29-03-2012, 08:57 PM | #402 | ||
Thailand Specials
Car is in for adjustable sway bar and rear camber kit, hopefully done tomorrow.
New tyres going on Saturday, Toyo Teo Plus, hopefully a bit more quiet. |
30-03-2012, 12:31 AM | #403 | |||
Just don't expect great handling or good wet weather grip, but if you do a lot of highway driving you'll really appreciate them. |
30-03-2012, 05:26 PM | #404 | |||
Thailand Specials
Unfortunately my mechanic couldn't fit my swaybar, but he did the camber kit for me. He reckons the swaybar is the wrong type and the links are wrong, which part numbers did you guys use? |
30-03-2012, 08:50 PM | #405 | |||
31-03-2012, 12:25 PM | #406 | ||
Damo, I did have the same problem. The guys fitting my springs and sway bar only realised it when they had the thing off. They managed to get a set of suitable links from the local Ford dealer, which probably erased a lot of the savings I made on the other gear by buying over the Net...
I'm not sure of the part number/s, but you need the ones that hang down like dogs' nuts. I believe they're standard on LS/LT's of most descriptions, and also on LV Zetec's. Anyway, this is what they look like, if that's a help.
His: 2019 Ford Focus SA Trend with Driver Assist Pack: 1.5 Ecoboost 3-cylinder (yes, 3 cylinders!), 8-speed automatic in Ruby Red. Hers: 2020 Ford Puma JK: 1.0 Ecoboost 3-cylinder, 7-speed DCT in Frozen White. |
31-03-2012, 01:11 PM | #407 | ||
02-04-2012, 07:15 PM | #408 | ||
Thailand Specials
+1 for Toyo TEO PLUS, so much more quiet than the Goodyear NCT Junk.
Though it seems the wheelnuts on these things strip really easy, my mechanic did up the wheels with an impact gun, and I rounded a nut getting it off with a damn cross brace, it just rounded it off. The tyre place got it off, but its totally rooted now, unfortunately they didnt have a suitable wheel nut with that big of a taper, either did Repco or my local auto store, so I'm getting around with 4 wheel nuts on my front left wheel lol. |
09-04-2012, 02:36 PM | #409 | ||
Thailand Specials
18-05-2012, 11:57 PM | #410 | ||
Thailand Specials
I blew a low beam globe this morning, thats two in 30,000km, I'm using Phillips +100s though, they have a shorter lifespan.
I should get around to replacing it this Sunday, not going to replace it with the super duper phillips +100 globe because I have a sneak peak of whats in the mail for me: |
19-05-2012, 09:03 AM | #411 | ||
I would love to fit a set of xenons to mine, trouble is for them to be legal they have be set up with headlight washers as well, which although not impossible could still be a PITA to install :(
19-05-2012, 09:27 AM | #412 | ||
Barra Turbo > V8
Damo any chance you can let me know the price of this set up, ive been tempted to order these lights for my focus but i havnt yet.
Im guessing you purchased the complete light, ballasts and globes yeah?
2011 XR6 Turbo Ute - Manual - Lux Pack - Twin 2.5" Stainless Exhaust - Antz Turboside Intake - CCForged Phatlux wheels - Tuned by LS Tuning and Performance |
19-05-2012, 11:59 AM | #413 | ||
Thailand Specials
So far with just assemblies and ballasts were at about $1300 shipped.
19-05-2012, 12:36 PM | #414 | ||
Barra Turbo > V8
Phwoar I don't love them that much, my ebay search continues.
19-05-2012, 02:52 PM | #415 | ||
Thailand Specials
If I didn't go genuine ballasts I could have knocked at least $250 off the price but to keep things easier in regards to mounting I decided to spend the extra cash to keep the **** farting around down.
The assemblies themselves are about $700, but its all genuine. They're also bixenon,which means one globe for high and low, keeps wiring simple. If you are game and willing to butcher a pair of headlights you can pry them open, cut a hole into the reflector, mount a HID projector in there and reseal, but Ford headlights are permasealed and its a massive bastard of a job to split apart. I got quoted $960 in labor to have someone do it for me if I provide everything. Works out cheaper just to buy genuine and if its genuine you usually face less issues. |
22-05-2012, 06:04 PM | #416 | ||
Thailand Specials
My passenger headlight blew on last Thursday, I procrastinated about it until yesterday after work, replaced it, this morning my drivers headlight blows...
So I replace it at work, then one of the clips snaps off the drivers headlight assembly, it basically just pulled out of its hole. Its sitting in there ok, the screw is tight but it moves diagnally a little bit. Good timing on the HIDs I reckon. |
06-06-2012, 01:57 PM | #417 | ||
Thailand Specials
The lights arrived today, one assembly has been broken in transit, the entire inside assembly is loose.
Not too happy. Also the wiring headfooks begin. Last edited by Franco Cozzo; 06-06-2012 at 02:18 PM. |
06-06-2012, 04:25 PM | #418 | ||
That's so annoying when you've been waiting for ages and it turns up damaged :( Who was it shipped through ?
06-06-2012, 06:48 PM | #419 | ||
Thailand Specials
DHL Airmail
Whats happened is one of the clips inside the assembly has snapped, so the inside of the assembly which holds the lights moves left/right/up/down. Emailed European Parts, I sent it via insured airmail, so hopefully things work out alright. On the upside, having inspected the lights, they have a factory connector, which looks the same as whats on my Focus, which are going to ballast power inside the assembly, plus highbeam, indicators etc. It could just be a case of plug it in and off we go. |
06-06-2012, 07:08 PM | #420 | |||
