Old 24-09-2006, 09:09 PM   #271
Fairlane63
Fairlane
Fairlane63's Avatar
Red face
Hi guys,
i remember seeing something about an easy fix for a rear shock rattle, but i can't find it again!
can somebody send me a link or something, cheers
Ford and Jeep....
both four letter words
2006 TS Territory AWD
2016 Everest Trend 4WD
Fairlane63 is offline   Reply With Quote Multi-Quote with this Post
Old 25-09-2006, 07:43 AM   #272
Timeshift
Originally Posted by towins
problem: cruise control does work...
dont take it to a specialist yet way will cost you heaps..
fix: under the steering wheel, at the base of the cluch there is a limit switch, that stops the crusie control when you push the cluch in. ajust the scew.
problem: speedometer has spikes..
fix: this is the sensor in the gear box, go to a ford dealer you can by a new on for about $50, it is easy to replace just undo a bolt and pull it out of the gear box... take off the gear and put onto the new sensor...
Is this at all in relation to the cruise control issue I have, the issue being that if i'm travelling up a hill and have cruise control on, get to the top, apply the brakes and turns the CC off, then i'm on straight and level road and turn CC back on, it seems to go crazy? I'd be at 65km on the flat surface, apply CC for the current speed, but for some reason decides to accellerate to 75km? Then slowly... slowly... begins to settle down to 65km again. It's a pain in the ****. Almost got me pulled over a few weeks ago.
Timeshift is offline   Reply With Quote Multi-Quote with this Post
Old 25-09-2006, 04:08 PM   #273
The Monty
Just slidin'
The Monty's Avatar
Problem : -20degrees of camber on the front right
Reason : Wont say
Fix: Camber kit $110
New Rotor $160
Wheel bearing kit and hub $110
Stub axle $150
Ball Joint $44
Alignment $40
Labour $242
Empty wallet after paying for it $annoying.
MD Mondeo - For the family
NP Pajero - For the adventure
Old 17-10-2006, 01:00 PM   #274
KWIKLIKA
Default Power window will not move.
Power widows will not go up. Several windows affected. Pulled out switches and then pulled the switch apart and cleaned contacts. Even though the contacts were pitted. Used what is called micro-scrub contact cleaner (similar to a scourer). No problems since.
KWIKLIKA is offline   Reply With Quote Multi-Quote with this Post
Old 18-10-2006, 12:29 AM   #275
wesomc
wesomc's Avatar
Originally Posted by relish
Hi everyone please help me,
I have looked over this forum and cant find anyone else with problem as of yet. I have a Ford AU II Forte its done 170,000 kms and still runs (touch wood) awesome, always been serviced etc etc.
However for a while now there has been a terrible boot leak. I have no idea what to do because the only thing people have suguested to me is the spoiler. Funny thing is that i do not have a spoiler. People have also suguested the licence plate, well first of all the water is running from the top of the inside of boot down, not up, but anyways i made those screws as tight as they could go.
Nothing works. Everytime its rains my boot is full of water, but not under the parcel shelf, only where the spare wheel is. Everytime i open the boot the top of the boot is drenched and its starting to rust. Obviously there is no way of testing this.
Has anyone heard or had this problem themselves, its driving me insane and the boot stinks of wet carpet.....everyone knows how bad that smells. Please help.
Luke
hey luke,
Tryin this forums stuff for the first time!!
Have seen water entry from seams where the rear quarter meets the boot surround (sometimes you can see small gaps where filler has been missed).
If all else fails, jump in the boot with a torch and get someone to spray around the rear windsreen and around the boot, works most of the time.
wes
wesomc is offline   Reply With Quote Multi-Quote with this Post
Old 19-10-2006, 11:47 PM   #276
EATurbo10PSI
Hi I own an 1999 AU XR8, the mast in the electric erial is stuff't, I have brought a new one but Im not sure how to replace it.
EATurbo10PSI is offline   Reply With Quote Multi-Quote with this Post
Old 20-10-2006, 08:21 PM   #277
8pAc
RDP #181
8pAc's Avatar
How does a broken ariel mast present itself does your ariel not go up or down or is the reception stuffed. My reception is stuffed but i think it is getting interference from the RDP ecu doobee i had installed.
Originally Posted by MRJUCY
Camrys like most Toyotas have always been ugly, poorly equiped & brain crushingly dull but that's what a lot of people look for in a car unfortunately. I like my fridge, it keeps my beer cold other people like them so much they want to drive them it seems.
8pAc is offline   Reply With Quote Multi-Quote with this Post
Old 20-10-2006, 10:19 PM   #278
EATurbo10PSI
Talking
Hi, yes the mast will not go up and down, you can hear the motor going but the mast stay's up, I need to know if I have to take the wheel and the body skirt off to fit a new one in and if so will it brake the clips that hold it all on? My son own's a EA that he has spent 1000's on with the Turbo and every thing, but I've only had my AU for a few months and Im not sure how to fix the ariel so I thought I would jump on here and see if anyone out there Know's. regards XR8
Old 21-10-2006, 04:32 PM   #279
EATurbo10PSI
: hi well its all good :thebirds: I fixed it, and eazy as lol. thanks any way :eclipsee_ XR8
Old 24-10-2006, 01:14 AM   #280
Timeshift
How expensive are these switches? Where can I get em from? My drivers side window stuffed up, cleaned it etc etc as much as I could but no go. I ended up putting it on the passenger side.
Old 02-11-2006, 01:38 PM   #281
Samford
Default Auto Transmission Problems
I have an AU2 and my transmission keeps slipping while im driving which causes it to jerk. I happens no matter how long i have been driving for. Does anyone know what might be wrong. It also stalls sometimes for no reason, usually around corners. Help!
Samford is offline   Reply With Quote Multi-Quote with this Post
Old 03-11-2006, 10:15 PM   #282
davids_gxl
I have an au1 wAGON,duel fuel.the brakes are a problem.need to up date to a two piston au2 brake assembly.some people might take the crap out of the au,but it is dam reliable.the best car i have ever owned.i am up to 263000 and still going strong.the cab i got a ride in the other day was an au2 with 930000 and still in service.try beat that with a dunnydoor.
davids_gxl is offline   Reply With Quote Multi-Quote with this Post
Old 04-11-2006, 02:38 PM   #283
Emerson
AUVCTGHIA
I drive an AU Fairmont Ghia....I have a problem, I can lock the vehicle...but the left passenger door wont lock...so if someone opens the door all doors become unlock....On very very rare occasions does the passenger door lock...can someone plz advise me....
Emerson is offline   Reply With Quote Multi-Quote with this Post
Old 04-11-2006, 07:10 PM   #284
goXF
Now AU powered
goXF's Avatar
I believe that means the actuator in that door is faulty and needs replacing.
First car: 1987 XF Falcon 'S' sedan, 82,000Km - 134,000Km
Current Car: 2002 AU3 Falcon Forte sedan, 51,000Km when purchased - NOW: 81,000Km.
goXF is offline   Reply With Quote Multi-Quote with this Post
Old 04-11-2006, 07:32 PM   #285
Stav
Smile
Stav's Avatar
The drivers seat is off centre to the left of the steering wheel.The seat or steering colum are not aligned properly.Very uncomfortable some days.
Old 05-11-2006, 10:18 AM   #286
AEF_Silver94
Falcon obsessed
whoa,thats great to hear,as i plan on keeping an AU for a very long time.
AEF_Silver94 is offline   Reply With Quote Multi-Quote with this Post
Old 06-11-2006, 10:48 PM   #287
therhett
how to remove the traction control from au 1
therhett is offline   Reply With Quote Multi-Quote with this Post
Old 07-11-2006, 02:46 AM   #288
StAndArdAU
Back in a Blue Oval
StAndArdAU's Avatar
this thread is for problems encountered dude not tutorials.
welcome
'13 Territory TX Diesel RWD. The Family Bus
'08 Mitsubishi Pajero. The Off-road Machine
StAndArdAU is offline   Reply With Quote Multi-Quote with this Post
Old 11-11-2006, 11:16 PM   #289
Umineko
Karasu
Umineko's Avatar
Having killed my DL LTD a couple of weeks ago after using a lexus as a bonnet ornament I now find myself the proud and happy owner of a 2000 model AU LTD so far so good, runs like a train, got the usual intermitent missing digits on the LCD display thingy (thanks to everyone who posted the dude in Morrabin's contact details, will be calling him Monday) the only thing that bugs me now is a slight hissing sound when I accelerate,it dies off once you back off the pedal. seems to be coming from under the dash on the drivers side, no real impact on performance just annoying anyone had a similar problem?
I had a similar thing on the DL just before the brake booster crapped itself but there is no reduction in braking efficency like there was with the DL.
Oh and hats off to the morons at ford who wrote the owners manual... had to reset the alarm (not difficult) but the manual says nothing about holding in the bonnet open switch or getting your ears blown out not to mention waking up everyone for 2 blocks at 7am on a saturday morning.
Little things aside I love my new beastie and hope it proves as trouble free as my dearly departed and sorely missed DL
Umineko is offline   Reply With Quote Multi-Quote with this Post
Old 14-11-2006, 12:11 AM   #290
Markcapri
Default CD's jammed in AUII
I have an AUII, 2001 XR8 with in-dash 6 stacker. (20,000K's)
The CD's keep getting jammed in the player, and can't be removed.
It has been repaired twice before, but keeps on happening.
Does anyone know if an aftermarket CD system will fit?? If so, type etc
Thanks
Mark
Markcapri is offline   Reply With Quote Multi-Quote with this Post
Old 14-11-2006, 02:19 PM   #291
XR Davo
XR Davo's Avatar
Just had the body control module replaced on my car. Got Ford to do the install as I didn't trust the local auto electrician as I think he stuffed original module whilst installing replacement aerial but couldn't prove it. Cost $850 ouch! Beware people.
XR Davo is offline   Reply With Quote Multi-Quote with this Post
Old 16-11-2006, 08:57 AM   #292
Mechan1k
Mechan1k's Avatar
Damn ... I have a spare BEM sitting at home ... could have had it for $20.
I know an auto electrician that can reprogram the BEM as well.
Old 16-11-2006, 12:47 PM   #293
XR Davo
XR Davo's Avatar
Thanks for the offer man, yeah if it happens again will definately look at a second hand unit. A lesson has been learnt.
Old 10-12-2006, 09:57 PM   #294
Fairlane63
Fairlane
Fairlane63's Avatar
Default door lock not... um...locking the door...
Interesting, I have a slow flashing of the indicator dash lights when I lock the doors and the right hand rear door won't lock........anyone know of an easy fix?
Ford and Jeep....
Old 10-12-2006, 11:11 PM   #295
Elements
Have an AUII S/SR. Had it for 200km
1. The battery holder in the remote comes off. 10 min soldering job (if that!) and they're both working A-OK.
2. Driving along, and then all of a sudden there was no power steering fluid. Wretched noise, no P/S. Tightened bolts, filled it up and on my way (happened less than 3 hours after I got it - the rack was replaced by Ford about 50,000km ago.....).
3. Rough idle. Under investigation.
Elements is offline   Reply With Quote Multi-Quote with this Post
Old 14-12-2006, 12:09 AM   #296
BAxtER
ive been 4490'd
BAxtER's Avatar
i have an AU2 forte DEC/2000...its been a great car only just hit 55000kms
the only problem it has had is when new there was a noise coming from the rear suspension, ford dismantled and rebuilt the back right under warranty and everything good ever since
BUT YES WE GET THAT POWER WINDOW PROBLEM ..the drivers side switch wont work sometimes for the passengers window...ps lowndes was robbed
BAxtER is offline   Reply With Quote Multi-Quote with this Post
Old 14-12-2006, 09:13 AM   #297
Mechan1k
Mechan1k's Avatar
Dirty contacts under the power window switch ... pop the panel out of the door and clean the contacts underneath ... this SHOULD fix it ... other than that ... the plug might have moved and lost connection too.
Old 16-12-2006, 12:38 AM   #298
duaned
duaned's Avatar
Yep I have the same problem and are anxious for an answer on this ASAP!
I also get a large "crack" sound emitting from the front passenger door/ jam/dash area when I go over harsh / sharp bumps and it's totally annoying. Anyone else have this and found a resolution?
duaned is offline   Reply With Quote Multi-Quote with this Post
Old 16-12-2006, 10:54 PM   #299
drunknwombat
Default Hand brake noise
Originally Posted by Autocade
747 FLI
I also have similar Handbrake noise problem
I have found from reading through Forums and talking to various Ford and Ford Service Department people that some IRS AU and even BA Handbrakes have an issue where they get stuck on resulting in a constant metal to metal sound
Mine has been like this since about 15000 ks when I first noticed
after first service
It has been in since for repairs approx 6 times over 4 years
It stops for a little while and starts again after about 1000 Ks
To date the rear rotors have been replaced once also replaced 2 sets of clips and 2 sets of handbrake shoes and i think a cable and still not fixed
I am learning to live with it now by turning up the volume or the air conditioner.
With my luck they will probably find a fix for it just before I sell it
I found if you reverse an apply the foot brake the noise will go
drunknwombat is offline   Reply With Quote Multi-Quote with this Post
Old 16-12-2006, 11:46 PM   #300
Sleeperau
Highway Taxi
I agree I found the same thing, an apparent problem with the AU. When I had a disc to disc diff replaced (same cable it went).
Close only counts in Horse Shoes & Hand Grenades. :evil_laug
Sleeperau is offline   Reply With Quote Multi-Quote with this Post
