25-02-2010, 01:02 PM | #1 | ||
I have to replace a rear wheel stud and was hoping the job can be done diy, has anyone replaced a stud and are there any special tools required?
any help appreciated. |
25-02-2010, 02:08 PM | #2 | ||
Buy genuine studs, my dad bought ones from repco or something and they wouldn't fit even though they were clearly the right ones
Current Blueprint 03 xr8 5 speed manual, Difilippo Quad Big Boy system, BPR CAI, BPR Custom tune, Underdrives 256rwkw BA manual Typhoon Fully optioned, 340rwkw@16psi (thanks Bluepower)! The old ride.... AU Fairmont, cammed beast, R.I.P you made my p plate years bearable! 150.8rwkw courtesy BPR |
25-02-2010, 04:56 PM | #3 | ||
All Bran = Regular Member
Some years ago I replaced ones that look like this http://autorepair.about.com/od/fixit..._stud_repl.htm.
If Ford ones are the same, simply bash out the broken/stripped one from the front and bash in the new one from the rear. Simple. |
25-02-2010, 09:18 PM | #4 | |||
I haven't done one on an AU yet but i think its an axle out job.
AU XLS. |
25-02-2010, 09:33 PM | #5 | |||
as above, just bash the old one out from the front. then the easiest way to get the new one back in is push it through from the back and tighten the nut back up on it to pull it through the hub. |
25-02-2010, 10:11 PM | #6 | ||
I did a stud on the rear of a BA wagon and the ABS/traction control sensor ring is in the way and needs to be knocked off 1st. I'm thinking it may be the same for AU but I'm not 100%.
AU XLS. |
26-02-2010, 12:25 AM | #7 | ||
fair enough, it is an au1 though, so there's a very good chance it doesn't even have abs...
26-02-2010, 12:51 AM | #8 | ||
Miami Pilot
Live axle - easy job.
IRS = axle out job.
26-02-2010, 02:31 AM | #9 | ||
Yeah it has a live axle, non abs so it sounds like it will be a reasonably easy job. thanks for the replies people!
