31-05-2005, 12:28 PM | #1 | ||
Adapt or perish...
Guys, just want to know what the BCM controls?
AFAIK, it's power windows and cruise control. What else does it control?
Carless
31-05-2005, 01:35 PM | #2 | ||
fully *** turboooo
everything but the engine and trans?
AU1 Forte 178.6rwkw @ 5 psi Highflowed T03, Intercooled Full comp insurance :nutsycuck
31-05-2005, 08:29 PM | #3 | ||
The BEM controls:
LOW SERIES MODELS • Manual control of illuminated entry and exit delay • Manual boot release with security time out and speed dependant disable • Remote central locking with hazard acknowledgment • Manual central locking • Remote drivers door lock /unlock • Panic alarm • Key in lock warning horn/hazard • Anti-Theft warning LED • Remote control for illuminated entry • Remote boot/ tailgate release with hazard acknowledgment • Door unlocked horn/hazard warning • Automatic door relock timer • Transponder challenge/response immobilisation • Heated backlight timer • Front intermittent wiper timer with fixed dwell, wipe on take off • Front wipe after wash timer with fixed number of wipes • Diagnostic capability of inputs, outputs and trouble codes • Diagnostic self test • Battery saver for dome, boot and glovebox lamps • Power window supply control with key off HIGH SERIES MODELS The additional functions to the low series are as follows: • Front intermittent wiper dwell timer with variable dwell and speed dependency • Front washer motor control • Instrument cluster illumination (LCD & Graphics) control • Power antenna control • Automatic headlamp switch off action with manual override • Headlamp warning chime, headlamps on, ignition off. Mid series vehicles use a high series BEM with a number of the functions disabled. Examples are headlamp delay, single dome lamp circuit, no front washer control. Cheers Russ
01-06-2005, 11:17 AM | #4 | |||
Adapt or perish...
Sounds stupid, but I'm actually learning something new here.
Carless
