Old 10-11-2006, 02:38 PM   #1
FESTEC
FESTEC's Avatar
Default Mk2 Focus Cai
Hi looking at getting a CAI and like the aem as had one on my SP23 but not sure if this is the correct one for the MK2 so can someone please confirm:
http://www.aempower.com/ViewProduct.aspx?ProductID=262#
FESTEC is offline   Reply With Quote Multi-Quote with this Post
Old 10-11-2006, 03:18 PM   #2
melbzetec
Old enough to know better
melbzetec's Avatar
Given I don't think the US has the Mk2 Focus yet, I would doubt it is the right intake. But I stand to be corrected
Manual 2003 Machine Silver 5 Door LR Focus Zetec.
Mods: Ford Racing CNC'd cylinder head milled .040", 3 angle valve grind. Ford Racing Stage II camshafts. Ford Racing cam gears. Ford Racing long tube header. Random Technology hi flow cat. Herrod 2.25" stainless cat-back. Pipercross Viper intake. CFM 65mm throttle body. 2000 ported intake manifold. Herrod Custom SCT tune. Eibach suspension. Quaife ATB diff. Wilwood 13" brakes. Custom ST170 leather interior.
www.cardomain.com/ride/2773918
melbzetec is offline   Reply With Quote Multi-Quote with this Post
Old 11-11-2006, 12:13 AM   #3
Zetec20
Zetec20's Avatar
us has a 'facelift' model with the duratec and a different front end, a kind of cross between the mk1 and mk2 a.... mk1.5 if you will....
Zetec20 is offline   Reply With Quote Multi-Quote with this Post
Old 11-11-2006, 10:47 AM   #4
BlackLS
Posts: n/a
The engine layout is fairly similar between the Bastard 1.5 and the 2. Hopefully the radiator position is the same, if it is then your set with that one.
But if your looking for somewhere local, just look for a Mazda3 cold air intakes, both the 2.0 and 2.3 have the same intake. They have identical engine bays, and you should be able to fit larger pods in focus between the radiator support and the front bar behind the fog lights.
Go custom at an exhaust shop IMO. For 400 landed of the AEM, you can get the piping made up and gold plated for the same price.
Old 11-11-2006, 10:53 AM   #5
BlackLS
Posts: n/a
Some pics to help planning:
Old 12-11-2006, 06:24 PM   #6
JD2004
JD2004's Avatar
that looks slightly different to my engine bay, i was thinking about a CAI upgrade myself but its alittle different in my baby :(
Luke
For Permeable Paving in Brisbane visit viastone at www.viastone.com.au
JD2004 is offline   Reply With Quote Multi-Quote with this Post
Old 13-11-2006, 08:05 AM   #7
BlackLS
Posts: n/a
i"ve taken the engine cover off
Old 15-11-2006, 02:49 PM   #8
#Russ#Es#
Hello Koni's!
#Russ#Es#'s Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: This member has made a few valuable contributions to the Forum in the Focus section, seems to know exactly what he is talking about with his posts, which are helpful and concise.
Thie following link may also be of some interest to some here >>> (not sure about the cost though...)
http://www.webcon.co.uk/Downloads/Alpha%20ATB500.PDF
2006 LX FOCUS SEDAN
Titanium Grey, factory bodykit, slightly debadged
CSA Motorvatr 17's/Kumho KU31's, Eibach Prokit/Lovells rear springs, Koni Sports Kit
Lower airbox removed, K&N Panel filter
Momo gear knob + boot + pedals, Ghia boot garnish, Zetec Chrome interior door handles
JVC KW-XR816 Headunit + more to come...
#Russ#Es# is offline   Reply With Quote Multi-Quote with this Post
Old 15-11-2006, 04:00 PM   #9
BlackLS
Posts: n/a
You'd need an aftermarket computer to run that... Thats where things get fun
Old 15-11-2006, 05:00 PM   #10
photn
AFF Post NAZI
photn's Avatar
I so want one that is designed for the Fez lol...sidedraughts are cool.
Old 15-11-2006, 05:38 PM   #11
Marshy79
JD you can find a fair bit of info on CAI intakes for the XR5 on the euro forums. There is even one thread with heaps of pics with some dude who made his own one up.
Marshy79 is offline   Reply With Quote Multi-Quote with this Post
Old 15-11-2006, 05:57 PM   #12
Conquest_Tsi
...and expensive
Conquest_Tsi is offline   Reply With Quote Multi-Quote with this Post
