18-08-2006, 09:56 PM | #1 | ||
V8's for ever
My headlights are in terrible alignment, they need to be raised up a bit to give more light at a distance.
Any one done this?? How do you do it |
18-08-2006, 10:17 PM | #2 | ||
Old enough to know better
Be aware that the left hand light (left hand side of the road) is supposed to shine higher than the right hand light (oncoming traffic). You might end up trying to adjust something that shouldn't be adjusted
Manual 2003 Machine Silver 5 Door LR Focus Zetec. Mods: Ford Racing CNC'd cylinder head milled .040", 3 angle valve grind. Ford Racing Stage II camshafts. Ford Racing cam gears. Ford Racing long tube header. Random Technology hi flow cat. Herrod 2.25" stainless cat-back. Pipercross Viper intake. CFM 65mm throttle body. 2000 ported intake manifold. Herrod Custom SCT tune. Eibach suspension. Quaife ATB diff. Wilwood 13" brakes. Custom ST170 leather interior. www.cardomain.com/ride/2773918
18-08-2006, 10:55 PM | #3 | ||
V8's for ever
interesting, I did actually notice that.
They are quite bad though. Im usually a good nite driver, never use high beams ever, but these lites just dont give enough distance at nite. |
19-08-2006, 01:06 AM | #4 | |||
1. The bulbs from the factory are absolute garbage and need to be replaced with something decent (which i can attest to... owning one myself, i agree, they are crap) 2. the alignment is out. there is an adjusment for headlight angle if i remember correctly, just under the headlight switch itself. maybe wind it all the way up and go from there. otherwise it requires endless fiddling with the angle of the headlight and bracket and it WILL annoy the living bejesus out of you : Uni/. |
19-08-2006, 03:28 AM | #5 | ||
There is a white hex (allen) grub screw, the top is visible on the top of the headlight. You might want to use a cordless drill to adjust this (just be careful!)
19-08-2006, 11:47 AM | #6 | ||
V8's for ever
cool ,thanx, will give it a try tonite when the sun goes down
19-08-2006, 05:53 PM | #7 | ||
Death B4 Decaf
Check the headlight adjuster next to the light switch if it's like a Fez. Had mine wound down without realising & wondered why I couldn't see ****.
06 fiesta Zetec in Tango. Factory scuff plates, mats, spoiler & leather gear knob. K&N panel filter. Focus clear side indicators. Colour coded. |
19-08-2006, 07:12 PM | #8 | ||
Focus on my Focus
Do any of our Foci even have that switch?
Now: 2006 Ford Focus LX Manual in Satin White Wife: 2013 Kuga Titanium in Frozen White Then: 1990 Ford Laser - Assasinated by a 76 year old man who failed to give way. Now normally when we have these races, Jeremy goes in the car and says "Powerrr" alot.... - James speaking about Jeremy (Top Gear S7 E05) American parts... Russian parts... ALL MADE IN TAIWAN! - Russian guy in Armegeddon |
20-08-2006, 11:26 AM | #9 | ||
Nope, South African Focus don't have the height dial. Not even on the Ghia. (although XR5 does)
Compared to the CL on the LR that had it. |
20-08-2006, 12:59 PM | #10 | ||
Death B4 Decaf
Ok, do they have a manual one on the actual light like my old 306?
20-08-2006, 10:07 PM | #11 | ||
Mine were also too low from new so I used an old alan key, foget the size now but the adjusters are easy accessed, just open the bonnet and there they are behind the headlight assy.
I keep the key in the glovebox now along with a set of T keys you will also need should a rear lamp blow. Also, if you drive a lot at night the standard lamps will need to be upgraded - standard headlights are rather marginal. There's another thread about this. |
Thread Tools | |
Display Modes | |
